It is currently Mon Aug 25, 2025 3:51 am
PostPosted: Sun Apr 21, 2013 4:09 pm
First name: Corky
Last Name: Long
City: Mount Kisco
I believe that mahogany is appreciated for its resistance to changes in humidity, in that it doesn't expand or contract very much. What north American woods share this trait? Looking for some readily available woods from lumberyards for making a three dimensional puzzle. Need the wood to hold its dimensions. Ideas? Thanks.
PostPosted: Sun Apr 21, 2013 4:26 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Pine is fairly stable.
Alex
PostPosted: Sun Apr 21, 2013 4:35 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Alex
No it's not. Pine warps and cups terribly, even when close to quarter sawn. At least, the stuff I use does.
Pablo Picasso
PostPosted: Sun Apr 21, 2013 4:47 pm
Last Name: Garrish
Plywoods! Sorry, it was the first thing on the top of my head...but it's true.
Baked woods! Ok, that was slightly more serious...cooking the wood ruins its ability to take up and release moisture, making it less warpy.
Maple is up there for least warpy woods, given how well it works in most any cut orientation in a million Fender necks.
So, in summation, maybe some of that carmelized maple would be the ticket? Even better if you made ply out of it, though :)
Bob Garrish
PostPosted: Sun Apr 21, 2013 5:20 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
in my experience, mahogany. both "true" and khaya, but not sapelle.
ebony is pretty bad, and madagascar rosewood is proving rather susceptible too.
PostPosted: Sun Apr 21, 2013 5:34 pm
First name: Alex
Last Name: Kleon
City: Whitby
PeterF wrote:
Alex
I have to disagree, Peter. The problem most people have with any wood warping or cupping is because once it has been dimensioned, they lay it flat on a work surface, restricting one surface from expanding/contracting, and not finishing all surfaces equally. Over the last 25 yrs, I've made a lot of cabinets and furniture from white pine, all of it flat sawn, without problems. My kitchen table where I'm sitting is three boards and 35" wide, and flat. Moisture content and equilibrium will also factor how any wood will react.
As a species, white pine is known to be stable, how we treat and work it will determine the results.
Alex
PostPosted: Sun Apr 21, 2013 5:55 pm
I always found mahogany to be pretty stable dimensionally.
PostPosted: Sun Apr 21, 2013 6:05 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
According to resources for sizing panels in 5 pc. cabinet doors, Mahogany is among the most stable woods listed with regards to change in RMC. But Maple, while having more movement tends to react much slower and can appear more stable on a daily basis on a guitar in a touring situation.
Brian
PostPosted: Sun Apr 21, 2013 6:32 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
Pages 16 and 17 show the coefficients of expansion (per % EMC) for common dried woods: http://www.fpl.fs.fed.us/documnts/fplgt ... ter_13.pdf
For a 3D puzzle, for the minimum Cr and especially Ct, Northern Catalpa looks best. Also Eastern Red Cedar (aromatic). Sugar and Eastern White Pine are good, other Pines more average. Their Mahogany numbers aren't very low, but the footnote says that data is over a wider MC range.
David Malicky
PostPosted: Sun Apr 21, 2013 7:44 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Mahogany, black walnut seems stable in my experience as well. I hear macassar ebony is stable too, at least relative to the usual ebony. But you are interested in North AMerican woods...so black walnut should work out for you well I think.
PostPosted: Sun Apr 21, 2013 7:50 pm
mesquite...most dimensionally stable wood I've worked with...
prime example: leak occurs in a house under construction...decimates the 1st floor....subfloor removed and trashed, oak hardwood flooring history...mesquite flooring in study felt wet to the touch, but hadn't cupped or anything...wood was removed, subfloor R&R'd, mesquite was allowed to dry and was put back down...
can't think of any other wood I've dealt with that would have survived that...hmmm...well maybe ipe, but I rather hate that stuff...
PostPosted: Sun Apr 21, 2013 8:01 pm
First name: Corky
Last Name: Long
City: Mount Kisco
David.
Thanks for this. Very interesting reading. I find it interesting in a number of ways. One is that many have suggested that persimmon, being very hard, might make a decent substitution for ebony as a fretboard or bridge material. But it seems to react very strongly to changes in humidity. Seems not to bode well for guitars built with it as a fretboard or bridge.
Also, maple looks good, and so do all those pines. And they are so different in terms of their hardness. Maybe I'm worrying too much about this.
PostPosted: Sun Apr 21, 2013 8:03 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Mesquite. That would be cool, and would smell good too. Not sure I can find pieces big enough to cut that would work for the piece I'm thinking of.
As for ipe, ugh. I think I'd need a very strong laser to cut it straight.
PostPosted: Sun Apr 21, 2013 8:05 pm
First name: Corky
Last Name: Long
City: Mount Kisco
thanks, Brian. I think I'm going to start with maple. Hard, pretty, and common. And if it's pretty stable, that's even better. You going to ASIA this year? I think I saw you at the last one.
Corky
PostPosted: Sun Apr 21, 2013 8:25 pm
well, I admit that I most likely have an 'advantage' on the subject of mesquite since a lot of it is milled here in Texas...but, I think you should be able to find a piece big enough for just about anything if you look a bit... http://www.mesquiteburl.com/mesquite-lumber.aspx ...can't give any recommendation about that place, just found it quickly on google...all of the stuff I've used has been supplied through middlemen...
I've dealt with some pretty big slabs of the stuff over the years (easily big enough to make an electric out of a solid piece)
PostPosted: Sun Apr 21, 2013 8:42 pm
I believe western red cedar is your best bet. It's even used unfinished for outside furniture since like forever.
Alain Moisan
(Now building just for fun!)
PostPosted: Sun Apr 21, 2013 8:46 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Petrified wood is pretty awesome but its a bugger to bend.
Doug
PostPosted: Sun Apr 21, 2013 9:45 pm
Black Locust or Honey Locust.
PostPosted: Mon Apr 22, 2013 12:01 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
PeterF wrote:
Alex
Southern pine does pretty well.
PostPosted: Mon Apr 22, 2013 5:37 am
Last Name: Howard
City: Magnolia
State: Delaware
Corky
Yes, I'll be there. See you then.
Brian
PostPosted: Mon Apr 22, 2013 6:39 am
Eastern red Cedar (smells divine). Not really surprising that it's pretty stable in respect to moisture. They use it in fipple flutes, Recorders etc.
PostPosted: Mon Apr 22, 2013 6:57 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Basswood (Tilia americana)
PostPosted: Mon Apr 22, 2013 7:00 am
Country: Romania
I did some wet-room tests and it seems to move at least as much, if not actually more, than African ebony. But it seems to crack harder, and it is definitely less brittle when flexing it. My samples were returned to the dry shop and a couple days later I found the black ebony cracked from the fast drying, the Macassar was in 1 piece and not warped.
Build log
PostPosted: Mon Apr 22, 2013 8:16 am
I have worked with Catalpa and that is about as stable as a piece of wood can be. There are a few factors you overlooked , and that is how it was dried. I find kiln dried to be more stable than air dried . Also the cut . while well quartered may stay flatter it may shrink and expand more than flat sawn.
All wood will move to a degree.
Petrified is the most stable and you don't need a filler
PostPosted: Tue Apr 23, 2013 12:28 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Cherry, sassafras, and black locust are some of the most stable domestic woods I have used. Walnut is also a good choice. I would stay away from sugar maple. Silver maple and bigleaf are much better, but not as good as the woods I recommended.
